k lets go this way i want to put the stock turbo on top. possibly modified something like bigger exh houseing and different compressor. but lets talk in terms of compressor sizes the stock hx is what 42mm? so i want something thats 40s range on top and on bottom i want what low 70s?
now here is what ive been thinking about doing stock turbo top sufficent big one on bottom, head studs, injectors mach 4,5, or 6s edge ez and tst stacked. the goal is as with any twins is to have the quick spool. i want something stock or close to it if not faster and good air flow from the bottom one. head studs if i can afford it so i can actually use the boost thats able to be made(if i cant afford these then ill wastegate at 50lbs till i can) the 2 chips and the injectors. now as far as priority of what i want. #1 turbos #2 chips #3 injectors #4 studs.
i know ya'll wont agree but im working on a very limited budget and right now i dont even know what that will be exactly i wanna know what will be the ideal setup and work out the price of the project and go from there.
