Also can be seen here at the bottom of the page:
QUAD 4 x4
This explains in great detail why we are going through balljoints like water, but when I replaced all four of mine, the bottoms were tight and only the uppers had play at 55k. Also check this out, cheap oe replacement bj's. Not the heavy duty greasbles but cheap though.
eBay Motors: 03-08 Dodge Ram 2500 3500 AAM 9. 25 Ball Joint Kit (item 280179254342 end time Jan-28-08 16:54:40 PST)
Dan the Gear Man Tech Note:
Worn Out Ball Joints on 2003-up Dodge Ram 2500 and 3500 Trucks.
Premature Ball Joint failures on 2003-up Ram Trucks is a reoccurring problem that will probably plague these trucks for their entire life due to the size of the Ball Joints and the steering geometry of the AAM 9. 25" axle.
The Upper and Lower Ball Joints on these axles are at different angles, in other words the vertical axis of the Upper and Lower Ball Joints are neither inline or parallel to each other. To compensate for the different arc of each Ball Joint during turns, the modest sized, straight shank, 7/8" diameter stud of the Upper Ball Joint is vertically free-floating in a 1" long sleeve. Consequently, the Upper Ball Joint does not support any weight, it merely keeps the knuckle in place. In fact the upper Ball Joint is not really a Ball Joint at all, instead it is a floating King Pin that is about the same diameter as the King Pins found on 1966-1981 Ford F100 4x2 1/2 ton trucks and light 3/4 ton trucks with GVW's of 4,700 lbs-6,900 lbs. .
The Lower Ball Joint is load bearing, in fact, the two Lower Ball Joints carry 100% of the front axle weight on your 2003 or newer Dodge Ram truck. Dimensionally, the outside diameter of the Lower Ball Joint is only 4% larger than the Ball Joints used on 1972-1986 Jeep CJ's (and other light-duty models of that era) which has somewhere between 1/4 and 1/3 of the front axle weight of the Dodge Ram, plus both the Upper and Lower Ball Joints on the CJ are load bearing. In addition, the Ball Joints used on older models like the Jeep CJ and 1994-1999 Dodge Ram 2500 and 3500* shared the same vertical centerline axis and were pre-loaded to compensate for wear. With the AAM front axle steering geometry using differing Ball Joint angles, no preload is possible, therefore, any wear means loose Ball Joints.
Yes, lack of lubrication with the factory AAM Ball Joints can be a factor, however very few of the failed Ball Joints we cut apart are suffering from a lack of lubrication. Replacement Ball Joints in both greaseable and non-greaseable versions are available from quad4x4.com, plus there is even an offset upper Ball Joint out there (which in my experience is both short-lived and of limited use). Installing Greaseable Ball Joints and regularly greasing them may provide longer service life, but with the AAM axle, chances are you will need to replace the Ball Joints on your 2003-up Ram 2500 or Ram 3500 4x4 truck every two to three years. One would not mind the short Ball Joint life so much if these trucks steered better than previous models, were not subject to "Death Wobble", or had longer tire life.
*1994-1999 Dodge Ram trucks with the Dana 60 Front Axle have Lower Ball Joints that are nearly 10% larger than the AAM axle. Average Ball Joint life for 1994-1999 trucks is close to 150,000 miles or 7 to 10 years. All 4 Ball Joints for those years carry weight and are pre-loaded to compensate for wear and dampen steering shocks.
Cutaway of AAM Upper Ball Joint** from 2005 Dodge Ram 3500 4x4
Plastic Thrust Washer
Ball Joint stud has approx. 5/16" of vertical free play to compensate for movement of Knuckle during turns
Thin Ferrous Metal Bushing with bronze inner lining. Bushing is subject wear from impact loads occurring under "normal" driving conditions.
Vertically free-floating, 7/8" Diameter straight shank stud does not support any vehicle weight. Design does not have any way to compensate for wear Ball Joints should be replaced anytime there is side-to-side or back and forth play (Vertical only movement is normal)
** Upper Ball Joint is really a floating King Pin
Cutaway of AAM Lower Ball Joint
Ball is surrounded by a thin plastic bushing. There is no preload on ball to dampen "Death Wobble" or to compensate for normal wear. The Ball Joint shown here was from a 1 year old truck with only 5,400 miles on it. The lower Ball Joint was full of grease, but already slightly loose.
Lower Ball Joints carry all the front end weight of these vehicles.
Outside diameter of Ball Joint Case is only 4% larger than that used by older and lighter 4x4's such as the Jeep CJ and Ford Bronco. All 4 ball Joints on those older vehicles were weight carrying.
QUAD 4 x4
