Just went camping pulling 5er toy hauler, loaded. My engine started cutting out with no throttle response, then back to normal. Was doing this randomly. Did not seem to be rpm, speed, temp related. Pulling about 15k, cruising at 65, 2000 rpm's, 1000egt's, level grade, 95-100 outside air, real smokey from fires(so cal), 13-14 fuel pressure, 20 boost. When it first started I was going through real thick smoke but I could'nt see this causing it. Pulled over checked my intercooler hoses, all tight no leaks. Started up grade, started cutting out real bad, no throttle response, would slow down to idle then suddenly pick back up. Cleared up for another hour or so than started again, randomly on and off. Camped, then on the way home randonly again. Acted like I kept losing boost pressure, blocked the waste gate hose and seemed to clear it up, but did not drive very far this way, was not sure if this was the problem ,although I did notice more boost pressure and power, Could my waste gate be bad. Only code was P1693, the old common one.
Ok ? Apps, waste gate, VP. Been reading but not sure yet, Any input would be greatly appreciated.
2001 PDRHX35/14, DDedge/comp, DD2's, ATS transmission and controller, PacBrake. Just black smoke when cutting out like it's not getting air just all fuel.
Sorry so long.
Sorry so long.
