The dealer I had it at on Friday had it hooked up to his computer for almost 2 hours, but kept telling me that since the boost was running high, he didn't have anything to compare it too... what the crap does that mean??? either the thing is failing the diagnostic tests or it ain't!
Also, tried resetting the APPS today... before I started, checked the voltage at the PCM (orange wire/blue tracer) and it showed . 12V... so I pulled the APPS off, but couldn't figure out how to adjust it and keep it set at the . 463V as shown on the tag... put it back together, showed . 08V! checked the DTC's in the odometer, and it threw a P0122, APPS voltage too low, as well as lighting the check engine light... . and interestingly enough, there was very little surging on my way back home tonight (2 hours highway) which really has me thinking that all my problems are tracing to the APPS... anybody know if those things are covered under the 5yr/100K mile warranty from DC?? If so, should be a no brainer, otherwise I need a good source to buy a new one... anybody know where I can get one?
update: this morning, check engine light was off, but still shows a P0122... . and much to my chagrin I found out that there are two cycles on the ingition DTC display, one for the PCU and another for the ECU... I felt really stupid when I saw the ECU sequence showing 4 codes! P0122, P1693, P0216, and P0234... that last one is engine overboost, which can only be caused by the Banks Quick Turbo and has to be why the dealer couldn't get the problem diagnosed... he told me that since the pressure was too high, he didn't have anything to compare it to and that I needed to reinstall the factory turbo housing and intake to get the right readings... . anybody had that problem with Banks stuff???? I emailed them this morning, still no reply.
