Need help guys, I finally got around to rebuilding the D80 last night. (i blew up the spider gears a few weeks ago. ) anyway, I installed the new spiders, and new clutches (factory LS). Now, this thing is so dang tight that when turning corners, it chirps the tires, like a locked or welded rearend. I dont mind it being a little tighter than stock, but this is crazy! I need to know it I should tear it apart right away and remove a clutch plate, or will it "break in"? Also, I talked to a few people and the general consensous was that my rear originally was put together wrong (clutches) and that I should change it.
here is an example (might have the wrong number of plates, i am just going from memory now)...
IE:
Clutch Plate = +
Clutch Disk = -
Spacer = =
Splined spider gear = *
how it was originally set up...
My understanding is that it should be installed like this
IE:
Clutch Plate = +
Clutch Disk = -
Spacer = =
