so i got an 02 dana 60 for my 96 wanted to get rid of the cad and get the bigger 2 piston calipers and floating rotors but the problem is that the axle does not turn over very easily it is very tight so i thought it may be the brakes so i pulled them not the problem than i pulled both hubs and both turn freely next i pulled both the axle shafts still tight i think i have it narrowed to the pinion gear berings so what all is involved in changing the berings and if i change the pinion gear bearings should i change the carrier bearings too and what all is involved in the swap
thanks
ken
thanks
ken
