I'm not sure how you would upgrade with OEM parts... the backing plates are welded in completely different places, and are completely different in themselves... . I don't see how you can physically make it fit on the stock backing plate, either..... Just my observations... The aftermarket caliper E-brake is similar to the older units used on tractors I've worked on before. Very reliable short term, but parking overnight may not be ideal. And adjustment is critical to prevent damage when changing pads or servicing due to the minimal movement design... .
The tech guy at Blackbird said the same thing... . that the e-brake caliper is sub-standard in quality and performance and unless you use it consistently, it will require repetitive adjustments. After he told me that, I'm torn between scrapping the idea of ever having an e-brake or taking a chance and getting the e-brake calipers. TDR member Vaughn MacKenzie ordered the kit and took pics of it..... the backing plates are 3/8" steel!http://s113.photobucket.com/albums/n...post photos/
