dana 70 rear left turns noise why
Power Wagons In
2 1/2" skyjacker softrides for front
old 70 was making left turn rapping hitting banging noise
opened it up the cross thingy was worn out replaced
all new 3 rd member, done
still makes noise banging sound in sharp left turns only
going slow, put limited slip oil in it
its a bad banging noise
mechanic sayas it will go away with use
both before and after new 3 rd member still makes same noise
why
is it normal
i kept the old gears used dana 80 clutched in the 70
bill
:p :p :p :mad:
Have you added the mopar friction modifyer? You do need it with a Limited slip. If you didn't add the modifyer it will pop and snap on turns.
Did the rearend guy soak the new clutchs in the stinky stuff ? What kind of gear lube are you using? Try Red Line 80-140 & Red Line friction modifier.
a while back I was getting a lot of grabbing from the LSD during turns, put in 4 oz. of the Chrylser friction modifier, from the dealer I think it was $ 5. 00 took care of the problem, it was probably 2 or 3 days of normal driving before I noticed the all the grabbing was gone, maybe I should have started with 2 oz? but in reading threads regarding this some people seem to have much better performance with Chrysler vs. brand X, also noted some people had to put in significantly more than the 4 oz. I put in, I would add 2 oz. at a time untill it goes away, some suggested driving figure 8's after putting in the fluid to work it in.....
The figure eights and or circles in a parking lot is recomended with all clutch type LSD diffs. usually noise goes away in a few minutes.
