On the 2500, the only difference between the 70 and the 80 is the ring gear size. The 70 has a 10. 5" ring gear, the 80 has an 11" ring gear. The axle shafts, brakes, and hubs are the same. Even the 3500 version of the 80 is the essentially the same with a different hub to accommodate dual wheels.
Because the automatic transmission couples the driveline to the engine through a torque converter, it does not shock the driveline as hard as a manual transmission can when someone dumps the clutch with a load on or behind the truck, or the when truck is used off road.
Dave
