That looks beautiful. Outstanding work.
Those guys know what they are doing and they repair axles that haul 20 times more than a little dodge truckI would be leery of doing such axle repairs while its still on the truck because axle alignment is critical for bearing wear and longevity. For this reason, when doing anything extensive which involves removing or moving bearing surfaces then its best to remove the differential and all internal components and use a jig to assure everything remains aligned. In a pinch if you're stranded on the road is acceptable but certainly not what I'd suggest as normal...
I just had my drivers side spindle replaced a month ago, same day, by Axle Surgeon (in my case, of Oklahoma....where the axle broke and destroyed the spindle) Axle Surgeon franchises are all over and their rates are very reasonable.
Have 5000 miles on it already and it's running sweet (and my boost is running about 1 psi lower overall, leading me to think the wheel bearing was in distress for a while.)
The early 2nd gens had smaller weaker brakes. 2000 on up were the better brakes and all manual transmission 2500, and all 3500, had the larger brakes.
My 2500 has the same brakes as the 3500 came with. And my stock style brakes will bring this 4 ton truck to a very abrupt stop if I need it to.
That said, the hydroboost system health is directly related to the performance of the brakes too. So a struggling hydroboost system will result in a weak braking system forcing the driver to exert more pedal pressure. Keeping the PS clean and run synthetic is important.....but most people never even bother to look at the PS fluid.
Manual 2500's and 3500's had Dana 80. Auto 2500's had Dana 70's. I think. Then there was the HY-35 and HX-35 different of the later 2nd gens, with auto's getting the HY-35.
Correct..
And the 1998.5 - 2000's automatic transmission trucks had the 12cm HX but was switched to the 9cm HX from 2000 - 2002 for faster low load spooling.
Wow @DMather , thats great you were able to get it fixed same day! How fast were you going when the axle broke? Were they the original factory wheel bearings? How about the passenger side bearings, did the Axle surgeon inspect them?
