Funny you should ask. My factory D80 limited slip is nothing but "slip". It has never in the 8 or 9 years I've owned it turned both rear wheels at once. Miserable junk.
So yesterday, I bought a used (less than 500 miles) Powertrax unit. Still has the original box and paperwork.
I wanted a Detroit Locker. But getting any good, specific info on converting the D70HD Detroit to use in the D80 has eluded me. Even here on TDR.
The detroit would also require me to remove the entire rear axle and take it to a shop to have the thing setup and installed. I can't find any local shop willing to do gear setups on the vehicle.
I got the Powertrax for less than half price and can install it myself. Supposedly, it will even install in "most" factory limited slip carriers. We'll soon find out... I had to move quickly on it and I should have removed a rear wheel and axle shaft to make sure, but I'm counting on my D80 being 35 spline. That's another of those questions you will find more confusion than specific answers for here on TDR or anywhere else.
The previous owner removed it because he carries a heavy slide-in camper and tows a boat and felt it was too aggressive for his needs. I like that.
It appears to function and be built very much like a Detroit and is made of some material 6 or 7 times stronger than titanium the maker claims. The sheer beef of the D80 makes a whole new stronger carrier unecessary, just like the Detroit is a "drop-in" unit for the GM 10 1/2 inch corporate 14 bolt rearend.
Another good thing, is that it is easily removed and returned to stock if I don't like it.
I recently also bought a Powerlock limited slip for the Dana 60 front axle in my Chevy K30. If I like it, I'll get one for the Dodge D60, too. Then maybe this Dodge won't be such a helpless weanie offroad.
Go to (click here>)
POWERTRAX BY RICHMOND VIDEO DEMOS and check out the second video clip. It shows a Ford in 4wd with open diffs, a Dodge in 4wd with limited slips in both ends, and an old Ford 2wd pickup with a Powertrax all simply driving the length of a section of conveyer rollers with one side of the pickup on the rollers. You will be amazed how worthless the 4wd, double-limited-slip Dodge is. Then watch the humble locked-rear Ford 2wd. Great video!
