Well here is the story.
While changing over to the mag-hytec cover I noticed some very large metal filings, looked like shaved chocolate attached to the magnet in the stock cover. To me it looks like shim material from the pinion and ring gears, or its shaving off entire faces of teeth from the gears in very thin strips. Now my question, its going in to the dealer this week for them to look at it, what should I expect them to do. Fix it, replace it, replace parts. If they infact just replace parts should they replace all bearings both innner and outer and pinion or shouldnt I worry about it? Also Should I reuse the oil or expect to purchase new. Thanks in advance for your input!!
2001 WHITE 2500 QC, LB, 3:54, 4x4, ETC/5-SPEED, HD TRANSFER, FACTORY FOG'S, AUTOMETER ULTRA-LITE PYRO & BOOST, BOSCH 275'S, JARDINE 4" IRRIGATION PIPE, BFG 285/75/16 ALL TA'S ON EAGLE SERIES 58, ICS NERFS, ARMA TUFF SPRAYED BED, EZ FIXED. 280HP, 750 FT/LB AT 1800RPM. MAG-HYTEC REAR WITH AMSOIL 75-90. 25000 MILES SINCE JUNE ****POLARIS 700 RMK RULES THE HILLS****
