JFaries said:
After thinking about it allot, Boondocker spells out where I am at. Thats because I often consider that no modification is required to begin with. The Smarty, by itself, meets all my needs and the rest is just for fun.
I had no clue there was such a radically different opinion about how to do this. What kept me from moving forward was that I really would have liked to install the M4's and keep my E-Brake. However, it seems most resonable to pick which the way works the best for you and go with it. As you get about the same Hp in the end. At pretty close to the same price.
Other than tapping the pump wire, what is the biggest point of contention?
Jim
OK, well I re-read your lead post Jim, and I think I've lost sight of the forest for the trees.
You made it clear that you don't to worry about EGTs-- the "Ronco" approach (set it and forget it).
The more I think about it, the more I think you'd be a perfect candidate for
Mach 1 injectors.
I installed a set in a friend's truck back in Cheyenne. He has an 01 6sp similar to mine, but tows a lot. He already had an EZ installed.
The overall results were very impressive. Most impressive was the smoke-- or lack of it. These were SUPER clean, even in 6000 feet elevation. SOP power showed that these M1s (rated at 65HP) were just as strong as my DD2s (rated 75hp).
Moreover, EGTs are never a concern-- even towing heavy at somewhat high elevations. He's well within the limits of the stock turbo, which he wanted because he too has a brake and wants to keep it. He bought a water/meth injection kit, because he wanted to play with it, not because he really needed it. That, and he's SUPER cautious about EGTs, preferring to keep everything under 1200, even towing heavy in thin air.
Most impressive is the fuel economy. On a trip to SD running empty, he was knocking out a steady 22-23 mpg, hand calculated. That's stellar for a 4x4 imo.
He ordered the M1s while I still had my DD2s, and that sealed the deal for me-- I was going to buy some Don M injectors, not a doubt in my mind. I was extremely impressed with them-- the combination of clean and power is amazing.
For a tow rig, I don't think I'd even go as big as the commonly-loved 1. 6s. You just don't need that extra fuel.
Now you're probably wondering why this guy who just spent a lot of words justifying Mach 4s is now recommending Mach 1s
First, I wasn't really trying to say that M4s SHOULD be used for towing, just that they CAN be. Also, high EGT is not a forgone conclusion, because there IS a driver present who has some say in how the vehicle is operated, and thus the EGTS that result.
But I lost sight of what you want your truck to do and be.
I've also found in life that I'm much happier if I err to one extreme or another with many choices. For example, when I buy tools, I will buy either the best of a kind in existence (that I can afford, anyhow), or I will buy the cheapest piece of junk I can find. I find that I'm often pleasantly surprised by how well the cheapies work, and never disappointed with the expensive stuff.
So, as it related to injectors, I would tend to go small (<70hp) or go really big (150 or more). So, if you want to be safe-- it's best to be REALLY safe so you can truly put your mind at east. Or if you accept that YOU are the only thing standing between you and danger, go as big as you think you will ever want to.
How many of us are on our first set of injectors?
