Did you take the ABS off , my 94 has ABS to the rear brakes , look around the hole truck with a flash lite , look for leaks , there is a valve that if your lose a wheel cylinder or caliper , the valve shuts off to the leaking part , giving you some braking to other wheels .
Try a hard panic stop on a clear road with some one watching the wheels to see that they all work .
