Dash "Creaking"
Diesel Dynamics or Dr. Performance
Truck held hostage
For the last 3-4 weeks, I've noticed that my dash (I think where it meets the A pillar) is starting to "creak" - not a squeek or rattle. Just a little at first, now everytime I go over a bump, RR tracks, etc. This is very annoying to say the least!
Anyone else had this problem? How about the TSB for "Instrument Panel Creak"? If so did it work?
1999 2500 QC 4X4 LB Auto 4. 10LS, Driftwood, CD player with Steering Wheel Controls, Power Driver's Seat, 275HP Injectors, Boost Regulator & Elbow, K&N Air Filter, Brushguard, Spray-in Liner, 285/75R16 BFG AT KO's, Nerf Bars, Black Diamond Plate Deep Well Tool Box, Mopar flat antispray guards (front and back)
2000 Yamaha Big Bear 400 4X4
NRA Member
Clint- there is a bolt @ either side of the dash that attaches it to the inner post above the kick panel. If you have a FSM, it shows these bolts, which are removed to allow the dash to pivot downward for service. It sounds as though one of these bolts may have loosened up a little. Hope this helps.
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring, cat,& muffler all stolen.
TXRam -
I thought I was experiencing a "chirping" that apparently was coming from the dash area... couldn't locate exactly where in the dash area. One day my brother-in-law were driving along and the noise appeared, he put a grip on the overhead console and the noise stopped; maybe this is your suspect noise maker also. Just my two cents worth.
There is a TSB about a squeaky dash. Check Fritz Ram Page for it. I saw it once prowling around. You have to use a pry bar to bend the ends of the dash so they won't rub and squeak. http://www.ecpe.vt.edu/~dfritz/ram_frame.html
Is a good place to look for TSB info. I can't find that one tonight but you might be able to. If it's not on his site it's one of the other members of the webring. Sorry I can't be of more help tonight.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,Combo EGT/boost guage,custom switch panel,PacBrake,Torque plate,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
My Ram had that creak but I give a rig 1 or 2 years to find all the problems (unless it's serious) before I take it in and the creak showed up 6 months after purchase and them mysteriously disappeared about 4 months ago. I was about to put the TSB mentioned on the to-do-list.
