Dash illumination
Overhead Gauge Consol
Idle speed fluctuating
Hi guys,
Just a quick question regarding how the dash heat/AC controls are illuminated on a '92. I suspect that there is a bulb behind there somewhere, but it has not worked since I've owned it and I'd like to correct it now. I can's see up behind there from below.
Thanks in advance, Jeff
You will have to pull the dash face off, or at least that's what I did. The only hard part that I've found is getting the 4x4 bulb back into the socket, dodge did not give me much wire to play with :mad:, hope this helped.
