I've had mine out few times:
a. Remove rubber cup holder and plastic sunglass bin.
Remove (3) ea 8mm hex screws on drive shaft hump (two on passenger side, one driver side) 5/16 6-point socket works fine. Pull out this section.
b. Remove (2) more 8mm hex screws on drive shaft hump. These hold down the center console section that is under the center dash recess section. Pull out this section.
c. On Mega Cab (only) this also holds down the backseat AC duct. Duct will impede removal of center recess section. Simple slip joint. Slide out this duct.
d. Remove two black 7mm screws (cross point screwdriver also works). Pull the center recess section straight down. It's clipped in, just a good tug.
e. Remove two more 7mm/philips screws, one each pointing up under cig lighter and power socket. Hard to see but you can feel them with your fingers.
f. Starting on edge next to shifter, slowly snap out the center panel. The SLT wood grain, or Laramie silver, panel does not come off, it is permanently attached to the center panel. There are eight or so spring clips that will be difficult at first, buy you should be able to ease out the panel with your fingers. Avoid using a screw driver. If you have automatic, to remove the panel pull the spring loaded shifter towards you for clearance.
f. You can hang the panel on the wires, or disconnect the harnesses. I left the harnesses connected and rested the panel on a towel to prevent scratches.
g. Radio is held in with (4) black 7mm/philips screws. Radio is clipped in but pops out with a good tug. Warning: The unique Dodge antenna plug on back of radio will pull apart if you are not careful. Be sure to grab the black plastic housing when removing!
