dash panels 04
good price on extended warranty ?
Not happy with my Di-Pricols!!!
GWoody
How do you get the blasted things off, I know there are som clips involved I've had the large one off directly below the steering column. I need to remove the one above the brake release handle. I've tugged a little but don't want to break it. :confused:
If you are talking about the panel that holds the light switch, pull straight out from the right edge (next to the steering wheel). There is a small gap between the panels that you can stick your finger into. It'll come out with the switch and a/c vent attached.
Hope that helps.
