Daully Spare tire/rim...?
How much is to heavy?
06 2500 rear springs
I just sold the 2nd Gen and went with a Mint 04. 5 3500 DRW 6spd. Truck does not have a spare. I am in need of one. Anyone know where to look for a rim? I know the rim is 17". What is the Lug Patteren and center bore?
These things are not easy to find!
SMitty
SMitty
Any tire store chain can look up the specs - the new trucks have an 8 on 170mm (older trucks use an 8 on 6. 5 inch and are hub centric). Not sure if the new trucks are hub centric or locate off of the 8 lugs.
Then, if you're looking for a steel rim to match the OE, check with tire / rim stores selling upgrades and you might find some taken in as trade ins. Junk yards with damged trucks, etc.
I have had a dually since September of 1995 and to be honest, I have only used the spare once in 11 years. If you have a problem with a front tire, you can always use one from the rear and run a single to get you to a tire store. Since I went to the Alcoa's I don't even rotate anymore as the rims run so true the tires do nto go out of balance.
If you do not have steel valve stems on the rear tires, I would recommend them. Teh rubber valve stems will fail over time and your inside tire will go flat - becuase of the dueal tire set up and running 10 ply tires, you really will not notice it unless you happen to park on uneven ground.
Good luck.
