Hello!
I am currently mulling over which direction to proceed with suspension/lift options. Hopefully someone out there has asked the same questions before.
Here's the background info:
- Truck: Rear GAWR = 6,084 lbs (i. e. exibits the usual jacked-up rear end look)
- Lift: Daystar 2" Coil Spring Spacers (want to level the nose with respect to tail height)
Questions:
1. What do ya'll think about this lift option? Does it require additional upgrades, such as longer shocks, dropped pitman arm, longer track bar, etc? With respect to a standard 2-3" lift kit, will coil spacers place more or less wear and tear to the overall system?
2. I have targeted 35X12. 5 tires on Weld S. S. II 16. 5X9. 75 wheels. Will I have enough room with the stock (jacked-up) rear suspension and Daystar 2" spacer up front to fit my tire of choice?
Thanks in advance for any insight...
jon
Questions:
jon
