The daytime running lights work when the park lights are on but do not work on low beams. The high beam indicator is lit when the low beams are on ( altho' dimly) and it is lit when the high beams are on (brighter). I am assuming that the daytime running light module has failed and I have searched my service manual and it says that the module is to be found on the drivers side fender well. I have looked all over and have found nothing that resembles the DRL module that I purchased. I would like someone to tell me where it is at so that I can replace it and correct the problem. If it does not have one, then I would like a few suggestions as to what is causing the lights to operate like they do.
