LSmith,
I cant talk about the DD cam. What I was trying to say is the practice of doing so is not smart for turbo motors.
One more tidbit. We are trying to cut pumping losses right? What happens to the boost when you blow it out the exhaust valve with overlap? You just created a pumping loss.
Further, any fresh air you inject into a stream of exhaust can cause the raw unburned fuel to burn late or in the pipe causing a higher EGT in the manifold.
Someone recently measured the drive pressure as high as 72 psi in a HX40 with a 12 housing. This is/was at maximum power.
One last clue. As we increase boost over the stock levels... ahh heck Im giving away too much already (censorsed)
Don~
Don~
