Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Engine/Transmission (1998.5 - 2002) DDI's
Engine/Transmission (1994 - 1998) Oil in turbo
2nd Gen Non-Engine/Transmission Inner Front Wheel Bearings on a 99
Any guys running DDI's and a edge EZ out there dino? I have that set up and want to know around what I have?
Also have a turbo master and have boost max at 30 PSI, does anyone with the HY get a higher Boost than that, and does it help much above 30 PSI
:-laf
I ran 223horsepower and 484torque with DD1's and an EZ with a DTT trans.
I think it was a stingy dyno.
Had a turnbuckle on my HY at 28psi, beyond that I hear you're just making hot air.
I put about 15K miles on that combo, but with an HX turbo. I made 30 PSI or so. I never dyno'ed the setup, but it should be real close to 300 HP at the wheels, that is basically what DD called Stage One Pro back in the day.
