ddp injectors
FYI "Classic Blue" now on shelves... my Napa guys are not real with it!!
MBRP MK96116 Muffler and Quadzilla upgrade
I just installed a set of ddp 90hp injector tips and so far so good. If you are going to be in there why not put in something with a little more uumph, like the fifties? Just seems like a lot of work to end with 25 horse. You'll probably get better gas milage with the fifties. I think
Too much power can cost $ too. Since I have a Smarty JR I think I would go with the 25 hp injectors. If I run on tow I might have too much torque for stock clutch maybe the Jr and 50hp would be way too much for the turbo too so more $. The injectors might add too much timing along with the Smarty. I don't know.
I dynoed 512HP at the rear wheels with the stock clutch on my truck and towed very heavy loads with it, it wasn't till I exceeded that number that it started slipping and it still didn't slip all the time. That was with my smarty on level 9, DDP 90HP injectors, and the 5in exhaust. I also think it would be a better idea to go with the 50's at least.
