DDT Again
Kelly Safari MSR
PTO wanted
Forgive me if I sound like a "boken record" but Vinnie and Bill deserve kudos again.
Was having trouble with my Pacbrake not disengaging( with the switch on). Called Bill and he recommend a solution. It didn't work. Called a different time and he shipped a new soleniod (thinking that was the culprit) right away. I installed it, still no fix. Called again and Vinnie talked me through the most likely solution for the problem. He was right! Not once did they make me feel like I was bothering them, or they didn't have time to work out a solution. WHAT SERVICE! They were even ready to come to the shop on Saturday(day off) and fix my problem. AWESOME!
Now, for those of you who may face the same problem...
If your Pacbrake engages, but when you step on the throttle and lose power, here is the easy fix: find the square microswitch box under the dash, near the firewall. It is bracketed on with a bolt. Loosen the bolt a little and move the bracket around a little. Press the throttle pedal. If you don't hear a "click" "click" from the microswitch, then move the bracket a little more. Repeat the process until you hear the clicking. If you get the click, retighten the bolt. The microswitch sometimes gets out-of-balance. If you don't get a click at all, microswitch problems!
Hope this helps someone in the future.
Keep On Raming!
Jim
Way to go DTT
Vinnie and Darrin are both model employees and are always ready to help.
I have been to Abbotsford on a few weekends and they are alway doing something for the benefit of the Company or Customer.
I am sure Bill treat's them well :)
Way to go Vinnie and Darrin :)
OOPS
Looks like I was in a hurry when I typed my original post (DDT and "boken").
For those of you who knew what I was referring to,it was OK; for those who didn't, it should have read: DTT (Diesel Transmission Technologies) and "broken. "
Did anybody see the new DTT decal that's available???? It is really sharp. I think you get one when you purchase a DTT product, or have them service your rig. If I knew how to post a picture of it, I would. Any suggestions???? By the way, I don't own a digital camera, but I do have a scanner.
