Well we got the '95 3500 back from Dodge today after a "frame transplant", its been in dry dock since 1/22/01! Was really looking forward to getting home... DIDN'T MAKE IT!
First the throttle got stuck, got to safety and discovered the cable is fraying and sticking in the sheath. Is this a dealer item only??
I figured I could limp home at a "fast idle", went to start it and the batterys wouldn't crank it over. Mom had her cellphone called the dealer they came and jumped it... fired right up. The teenage mechanic put a voltmeter on the battery terminals got 11. 7 volts. He insisted that it was normal, I have always understood that you will get 14+ or so volts when the engine is running IF the charging system is working.
Well I figured get this truck home and fix it over the weekend. So I gave it throttle till I got 1500 RPM (it stuck there) and off we went with Mom following. Made it about 3 or so miles and I realized I was going dead (batterys) no charge. Parked it said a few words and slammed the door. Mom called auto club figuring we would get it home and work on it... . they said they can't tow a truck like that!
I'm home now in hopes of the bros and their immense knowledge to guide me in the right direction.
First, has anyone out there found a source for throttle cables besides DC or is that a DC item only?
Second, any ideas on the charge system failure. . is there a fuse? Any ideas would be GREATLY appreciated.
MAN I'M PI$$ED!
Thanks for the time and I look forward to any ideas.
Mike
9535hundred
MAN I'M PI$$ED!
Mike
9535hundred
