We have a 99 3500 at work that is used as a small snow plow. A few weeks ago it sputtered and quit pretty much all at once. 135K miles... original lift pump... and the VP44 was toast. I warned them... but oh well.
Anyhow it wouldn't start... nothing. The check engine code was for the APPS (throttle position). But the diesel shop assured us it was caused by the injection pump. They installed a reman VP44 and a FASS DDRP direct replacement pump. All good.
Today it sputtered on me at 5mph and the check engine light came on. Then about 15 min later it had a dead pedal. Just idle. Then it came out of it and was fine. The shop said take it back to the diesel repair facility we used.
They said the code was again APPS related but their "computer" showed the APPS was working fine. The fuel pressure from the new lift pump was good too. They were really at a loss and recommended a new APPS anyway.
Can this be the only real cause now? I don't want to start throwing parts (expensive ones too) at this gremlin. I suppose the reman VP could be the issue too but I'm ruling that out right now.
They are a reputable shop many here are familiar with. I just don't want to throw names out there as if they are not good. Because they are. I'm just not satisfied with the answer I got too much... especially since I was also told the same bad part was good too.
