I've replace the vp44 so many times it feels I'm getting sick of them.
Who are you getting your VP44 injections pumps from? Are they providing new PSG's ? Has the pump been run and calibrated on the Bosch 815 test stand?
My experience with VP44 fuel injection pumps has been opposite of yours) My original VP44 failed (same 0216 code as yours) at 64,000 miles. I drove it for another year (20,000 miles) and then had it replaced under warranty. At the same time and also under warranty, an in-tank lift pump was installed. I currently have 380,000 miles on the truck - over 280,000 on the VP44 and still running strong.
I encourage you to not get caught up in the lift pump pressure needing to be over 14 psi to push fuel through the 14 psi overflow valve on the VP44. Lift pump pressure has no bearing whatsoever on how much fuel passes through the 14 psi overflow valve.
Inside the VP44 there is a fixed displacement vane pump (referred to as a feed pump in the Bosch service manual). Its pressure is regulated at over 100 psi. The flow from that pump feeds all of the components inside the VP44 and sends fuel through the 14 psi overflow valve back to tank the instant the engine starts an idles. Since the the VP44 is driven by the engine, the feed pump flow inside the VP44 doubles when engine rpm doubles.
The lift pump pressure on my truck averages 3 to 6 psi while driving. It is 12 psi at idle. I have no fuel pressure concerns.
Be sure to get a new PSG on your next VP44 and be sure that it has been calibrated on the Bosch 815 test stand.
- John
