So, how did the installation go? Notice a difference with the new bushings?
Thanks
Install went fine - - it was hard doing the bushings, but followed the advice and drilled out the old one and then used a saber saw w/ a metal blade and cut a groove in the outer metal part and they came right out - - did screw up using an inpact wrench and messed up the new bolt, so I put the old one back in and went up to ACE hardware in Robertsdale, AL and they had the 9/16" bolt it takes. so then it was back to Summerdale to put in the new bolt with a socket and rachet this time.
I still felt loose, on the drive to Franklin, North Carolina (never had any bounce) but I found a tie rod end with alot of slop (the one at the pitman arm) replaced that, then found the tie rod on the drag link wasn't good either so replaced the drag link. Stopped at Geno's on the way north and picked up a BD steering box stabilizer and installed that as well.
Front end feels better but it still feels loose, so since I'm probably gonna' need ball joints, and I went through replacing the front wheel bearings on my '01 at a cost of almost $700. 00 each side, plus the wrecker bill (got stuck in Chicago that time) I've decided to go with the Solid Axel (Synteck sp) system an we are after the 1st of September, headed to Ohio where the front bearings will be replaced with greasable ones and lockout hubs installed. MAD 4WD in Portland, Ohio is going to do the work and I'm going to have then put new ball joints in at the same time. Hope to gain a little mileage and well as having all new front end parts installed.
