2nd Gen Non-Engine/Transmission death wobble
I could use some help. I want to put on a 2nd. steering stabalizer. Is there a kit available. One of the posts I read suggested that my Dodge dealer might have one disigned for my 96 4x4 duelly. I just don't think I should have to replace the steering gear box as some have done. Does anyone agree. I have put on a Links track bar, but that has not solved the problem. I have put on new tires and shocks also. Neither are new anymore, but it just seems like an engineering design flaw. Any help would be appreciated.
A '96 4X4 should have a stabilizer on there stock. Make sure it still has oil in it, you might have to take it off to test it. The biggest effect on death wobble (assuming everything is tight in the front end) is to have the alignment done and have the caster set very high (5 degrees). This will keep the wheels seeking true forward position and not wobbling.
