Has anyone tried this out there? A 24 decibel reduction would be huge! The email below is the company President's response to a query from me. Is the noise nazi out there somewhere? I'm in the "wife hates the truck because it is too noisy club. " BD
Thank you for your inquiry into our Dodge kit. The inside cab noise is about 95 dB without any protection. The Ho Cummins is even louder unfortunately. After kit installation you should be around d 71 dB inside cab. You can actually talk and hear your radio without blasting the radio over the engine noise. I am including a post from one of my previous customers who like yourself thought about putting the kit on, it works and there is no other way to reduce the noise inside unless you go to great lengths to put sound materials inside the cab that really is an expensive way to go and you need to tear out your rugs etc. The three pieces most critical are the valve cover, oil pan and manifold/turbo.
Regards,
Tim Thompson
www.atpwrap.com
-----Original Message-----
Sent: Friday, May 30, 2003 2:45 PM
To: -- email address removed --
Subject: noise reduction kit
Hi:
I have a 2002 Dodge Ram 2500 with the 6sp. and HO Cummins. What are some typical in cab Decibel reductions from installing the basic kit? If you have before and after numbers that would be very helpful.
Thanks,
Bratton DuBose
Bozeman,MT
Regards,
Tim Thompson
www.atpwrap.com
Hi:
Thanks,
Bratton DuBose
Bozeman,MT
