Ok guys and techs here's something to scratch your head about. . My friend has an 01 Dually with a H. O. 24V 6 speed. Here are the mods.
1. TST Powermax Comp box.
2. Lightning 2 Injectors from Scheid 150HP.
3. 95 GPH Fass Fump
4. Brand New VP 44 pump from Industrial Injection
5. 4" exhaust directly off charger to twin 4" stacks.
6. A Bigger charger (I'm not exactly sure what size but it's almost equivalent to a 64 super by Industrial Inj) but I do know it's definately way bigger than stock. .
Now here's what's going on. . Driving (WFO at about 3000RPM's) down the street this truck runs with no flaws and produces about 30psi boost max. Smokes like a freight train, fuel pressure stays right at 15 psi and the the truck doesn't hesitate, spit, sputter or nothing at all. It runs flawlessly!!!
However we are having a problem when he is hooked to the sled. Going down the track the truck smokes pretty heavily although normal (nice even steady cloud from both stacks) and then all of the sudden the engine just quits fueling (such as like he has hit the speed limiter). The smoke stops engine idles down slightly and then all at once resumes it's Wide Open Throttle. Depending on where he is on the track determines how many times this happens during a single pull. So far it has consistently done this 3 times per pass. To us it seems like the engine is defueling itself and then fueling again. . Oh and during each pass he is taching approximately 3000 RPM's and is carrying a steady 30 psi boost and the fuel pressure stays right at 15 psi.
TST states that it has an anti-defueling device built into the comp box and therefore should not be creating this problem. The box is currently on it's way back to TST for inspection. . Does anyone have any suggestions or has anyone ran into this problem before?? Please help me if you can!!!!
3. 95 GPH Fass Fump
