I am going to use . 5gph moderate pressure (45 psi) misters on 2 fuel coolers I use to cool the fuel being delivered to the VP44.
The tank I had made has a 9" screw opening in the top and I could even make a water / ice mix depending on what I was misting. If misting the fuel coolers only a water / ice mix could work I think. As the component to be cooled runs hotter (transmission cooler, intercooler) the stress caused from the large temperature difference of the mist and the component would probably rule out using a water / ice mix.
Neither fuel cooler goes much above 140*. However I want to be able to deliver 100* or less fuel temperature to the VP44 under any condition. I would like some discussion on what demineralized water mix or additive (with what and in what proportion) might lend itself to the minimum scale deposit.
Secondly I might mist the transmission cooler (temps generally less that 200*) as a second experiment. Again what water mix and in what proportions, what additive?
Thirdly, and would be lastly, and might not even be a player, to mist the intercooler / radiator system. This is the hottest system and probably the most prone to scale from hot instant evaporation on contact. Although the most temperature sensitive due to the larger heat range, the engine cooling is not a problem.
Just looking for ideas for the cooling fluid, and some general discussion.
Bob Weis
Bob Weis
