Replaced with these Dexter products.
A leaky grease seal would have prevented all of that salt corrosion.
Ex boss had a salt trailer with disc brakes I'd never seen anything like it absolutely destroyed.
I'm wondering if you understand how the hubs work.
I can only conclude that you have never really purged the old grease from both bearings in all the hubs on the trailer, instead pumped a couple shots into each zerk and called it a day.
I did read that and they do have a large list of grease listed by MFG and name of product.@GAmes Thanks for sharing. Our 28' cargo trailer had the brakes fade away after we rented it out for daily cargo use. It had blown off a grease cap and painted the side of the trailer with grease. I would agree that they were overfilled with grease and frankly way overdue for maintenance. We didn't keep it long enough after we got it back to see if the brakes/magnets had worn out or if it had bad seals. Hauling cargo daily we had worn out through several sets of ST tires aside of the OEM ones that made two weeks before separating.
Other cargo trailers we used from the broker had the magnets wear clean through and short out, broken springs, and all the other fun of high mile daily use of a trailer with light duty axles.
I pulled the bearings on a smaller single axle cargo trailer I had for years and wound up replacing all of the bearings as the races were fatigue flaking.
The warning about grease from Dexter's site is interesting.
The maintenance schedule to inspect brakes and bearings is suggested 12,000 miles or 12 months. I don't see many people following that. Page 84.
https://www.dexteraxle.com/user_area/content_media/raw/600-8k_complete_service_manual.pdf
https://www.dexteraxle.com/Contact/FAQ/Bearings
WARNING: It is important NOT to mix different types of grease thickeners. The grease that Dexter Axle uses has a Lithium Complex thickener. Mixing our grease with a Barium, Calcium, Clay, or Polyurea soap based thickener agent will cause adverse effects. This may include causing the two greases to harden, separate, become acidic, or pose other hazards and damage to the bearings.
As I stated, I plan to pull the hubs this summer since the trailer is 10y old, I bought it new and have done all the service with 3 cross country trips,. no issues
I'm confident that when you pull the drums you will let us know if there is any leakage, or not.
I think they list the compatible grease in the book, just don't want to mix up the different types is what it was looking like.I figured Lucas red and tacky was a good wheel bearing grease but it’s not on the list. I believe my camper has lippert axles anyway.
Nothing special about that. I still have my original tie rod ends using Valvoline grease.
Per my Frame and Axle guy he said my truck should be the poster child for Dodge ram 2nd gen at 300k he said all the others were shot he worked on at much lower mileage.
Two things I wanted to quick comment on.
My front hubs are just like the trailer axles. Bearings and how to install them are exactly the same procedure. I have my truck on a 50,000 mile inspection and repack schedule.
Also, this is an EZ lube brake drum from my brand new 5er that had poor braking when I brought it home. As you can see "from the factory" isn't always good. Three of the four brake drums had grease in them.
View attachment 133467 View attachment 133468
