You can take them apart for relube if careful. Remove the drum with bearing, lay cap side down on a piece of clean wood, look in the spindle bore in the bearing and use a large screwdriver to tap the one half of the bearing and seal out. Clean and relube both halves in the same manner, tap the seals back in place. Reinstall the drum and torque the nut, good to go.
Ron
