Di-Pricol Gauges
fleetguard filter question
Motor Oil Brands
ETurner
Anyone out there have Di-Pricol gauges?Did you have any problems with them. Would buy them again?If you have them mounted under radio, do you have a problem seeing them?
I have DiPricole 03 dodge gauges. They match the stock gauges almost perfectly during the day but I'm not happy with how thay look at night. A lot of white light comes out around the face of the gauge anf they don't look anything like the stock gauges at night.
I the end I'm glad I mouted them under the radio because they might get annoying on the pillar. There's a picture of my mount in my readers rigs album. They are not difficult to see but are a little out of the way to look at.
-Scott
I had them, they worked fine,but I never liked the lights they put in them. They are just to small and at night I couldn't see them. So I threw them away, and got autometer ultra lite's, They have great illumination and are very easy to read at night.
I am running them on my 03 also, but have no issues with them matching. Mine look good at day and night. As for problems, I haven't had any issues there either.
I love the gauges, they match the oem's quite nice. (03') They look good at night also, the egt is a little brighter than the other two... but overall they are real nice. Mine are mounted on the pillar.
I am running them in my truck. Granted my truck is a 2000 model but I absolutely love them. They're not a perfect match at night but I am extremely satisfied with the quality and look of the gauges. I believe I read somewhere that Di-Pricol is a supplier to Caterpillar so I believe they are quality units. I'd definately buy them again in a heartbeat.
Reb [><]
Just got mine done this weekend, thanks NETDP guys. They match the factory perfectly, day or night. Work great. Look great, I couldn't be happier with them. Mounted them on the pillar. Looks like a factory install. :cool:
Here's a question for ya'll. When I installed my set I just went into the fuse panel to get power for the LED backlights. I'd like to have it switched on with the headlights like the rest of the dash lights, but I don't know what wire to tap into. Where did ya'll splice into the wiring? I'm thinking it's going to be one of the wires from the switch, but I don't know which one.
Brian [><]
You can look in your fuse block for the fuse marked int lights,I used a fuse tap and just hooked it up there with the fuse, some of the guy's here have posted thry used the wire on the ash trat light, ither place the light's on the gages will dim with the dash light's. hope this helped. Harv
