Anyone ever fight an incorrect diagnostic fee on a vehicle at a Dodge dealer?
It's a 98 12 valve..So your truck has a manual shut off solenoid but they told you need an in tank fuel pump?? What year is your truck???
I manually pushed on lift pump plunger and heard the OFV squeaking... does that not confirm it was getting fuel to the injection pump? Definitely correct me if it doesn't.Hmmm... Thats a tough one because they did diagnose it. Where they're going to get ya is they likely didnt disclose in their paperwork (which you hopefully have) that the truck isnt running and wont run without the in-tank pump they said you needed. If thats the case then you'll likely be looking at threatening them with a small claims case in attempt to get anything back. But with the filing fee being just about the same as what you paid them, I'm guessing its not going to be worth your effort if the service manager doesnt agree with you.
What I dont understand is if you knew it was getting fuel then it should have started... So how and where did you discover it was getting fuel?
That's exactly what I was thinking. I think I'll prevail on this one.From the wording of that ticket, they thought your truck is a 3 gen. Add on that your truck is not stock really spun them out. They’ve proven that they don’t know the first thing about mechanical Diesels.
Once they see their error, they SHOULD be willing to work with you.
I totally agree... I was in unknown territory and in a dilemmaA reason not to take an older truck (or older anything else) to a dealer if you can help it. The tech may never have seen one before.
Since when do 98 12 valves use an in tank pump back then or ever as a replacement. They were never retrofitted with an in tank pump and wouldn’t provide enough or the proper pressure even if they did do it
