Engine/Transmission (1998.5 - 2002) dialing in 47re
Engine/Transmission (1998.5 - 2002) 2002 47 re
Hey guy's ,I rebuilt my trans and have been trying to dial it in using another valve body from my other trans ,I have put the same shift correction kit in both of them and adjusting TV pressure and changing springs, but one problem is still there , when I floor it and she drops into passing gear the engine races sometimes , could that happen if I left out a clutch plate ? , I am missing something she has 3300 in parts and I had a true triple disc built billet this and billet that and kolene's :confused:, also I put in a heavier spring to raise pressure and have that backed all the way out and she is still shifting a little hard , should I go back to the stock spring , because I have that big torque converter ?
