Grease fittings, that is!
Just did a "grease job" on my truck - if you can call greasing 2 fittings a "grease job"... I knew from reading here and some initial looking around under the truck there weren't many - but expected more than *2*...
All I could find were the 2 on the drag links in the steering - NONE anywhere in the tie-rod ends or upper/lower balljoints - none in the driveline/universals or slip-tube at the center driveshaft support... Is that ALL there are?
I haven't heard anyone complaining about premature mechanical failures in the steering/suspension - do the greaseless joints REALLY work well in trucks like these over the long haul?
