how do those ABS sensors come out? Are they pull out or screw out? Thanks.
1 Raise Vehicle
2 Remove 8 Wheels Lugs (1 set per side)
3 Remove the 2 24MM ( use short socket they are factory tight) bolts on the Caliper
4 Support caliper with something or place it on a stool, its heavy so don't destroy the brake line.
5 Remove the rotor, it will need to be pounded off, be careful and don't ding up the Rotor take your time getting it off.
6 Remove the ABS sensor Bolt #5 hex
7 Use WD-40 or whatever lub to remove the ABS sensor take your Time work it form both ends and it will pop out.
8 (Make hose) Its 1/4"flex tubing (Clear) and 1 straight grease zerk, I heat gun the end of the tubing then put the Zerk in and Quickly Zip tied. Sometimes the zerk falls out ,then I just repeat the process (cut off about 1/2") because the tubing gets hard. Really take your time getting the sensor out so you don't break it off, just work it .....with WD-40 or whatever lub you have.
9 grease the hub ( look inside 1st to see how dry) it may take 40+ pumps use wheel bearing grease. Watch the inner seal when full grease will ooze out, after driving some grease may burb out the seal this is normal, keep turning the Hub when greasing.
10 Install . Never-seize the ABS bolt ,then reverse order TQ wheel lugs to Factory specs, then drive and recheck lugs TQ
