Engine/Transmission (1994 - 1998) Did this ever happen to anyone else?
Engine/Transmission (1998.5 - 2002) New Turbo Advice
Engine/Transmission (1998.5 - 2002) Turbo housing color change
On my way to work on Fri. the guy next to me told me I was leaking diesel fuel. When I pulled over to check , It was pouring out underneath from the engine. I automatically thought my return line finally sprung a leak. I had my brother bring it home on the rollback, I found the return line, and when I went to loosen the first clamp, I bumped the fuel filter housing and it moved. After further checking I found out the 3/8 grade 8 bolt holding the housing on had broke right under the top plate.
The truck was still running great,I don't understand how it wasn't sucking air with the amount of fuel it was pumping out.
Plus , why did it break now. I replaced the filter on Jan. 3,... 9 months ago, and I only tighten the bolt with a 9/16 x 1/2 open end wrench.
Any way I replaced the bolt and put in a new filter, and we're back on the road again.
Any one else ever have this happen?
Your engine wasn't sucking air because the filter housing has pressure on it..... 15-30psi... . Whatever the lift pump is putting out being regulated by the overflow valve. . Your overflow valve was getting a break by not having to return as much fuel as normal :-laf... I did have my return line give out a couple years ago. Got home from work and my boy said theres a big puddle of oil under your truck. I thought he was joking till I looked at it :eek:... Its always a shock to see your truck bleeding.
