Nano fuel additive enters efficiency trials
Miracle fuel additives that promise more kilometres per litre, cleaner engines and less pollution are as old as fuel itself. Such claims are often vague and rarely proven.
But now a British firm says it has developed an additive that makes diesel burn more efficiently, producing fuel savings of 10 per cent. And the UK's largest bus operator is running large-scale tests to find out for itself if the claims are true.
The diesel additive, called Envirox, has been developed by Oxonica, an Oxford-based spin-off company from the University of Oxford. It consists of tiny particles of cerium oxide, which catalyse the combustion reactions between diesel and air.
The cerium oxide functions as a kind of oxygen store. It releases oxygen to oxidise carbon monoxide and hydrocarbon gases to form carbon dioxide, and also absorbs oxygen to reduce the quantities of harmful nitrogen oxides. The result is a cleaner burn that converts more fuel to carbon dioxide, produces less noxious exhaust, and deposits less carbon on the engine cylinder walls.
Surface area
Cerium oxide has been studied for some time as a fuel additive but has never become a commercial success. Oxonica hopes to do better by using particles a mere 10 nanometres across to create a greater surface area for catalysing the reactions.
Envirox can be used at only five parts per million in the diesel fuel - one-tenth the concentration of previous additives. The smaller particles also remain more evenly distributed in suspension than larger particles.
Oxonica says it has successfully tested Envirox during 12 million kilometres of trials on buses in Hong Kong. And now the UK bus operator Stagecoach, based in Perth, Scotland, is putting it to the test in 1000 of its 7000 diesel-fuelled vehicles.
"The claim requires very carefully designed validation tests under real operating conditions, with real vehicles on real roads. We are keeping an open mind," says a spokesman for the fuel company Shell. "A 10 per cent improvement would be very significant. It's huge. "
Doping test
Meanwhile Oxonica is considering other modifications to the additive. A recent patent filed by the company claims that coating the nanoparticles in an organic solvent called dodecylsuccinic anhydride helps them disperse better within the fuel (WO 03/040270).
The patent also claims that doping the particles with a conductor such as copper can make the fuel burn better. This could improve the catalysis reactions by making electrons more easily available to the reactants. However, Oxonica is staying tight-lipped about the details and is using only the undoped particles in the Stagecoach trials.
"Will we publish the results?" says Nigel Havlin, group technical director for Stagecoach. "We have not entered into any secrecy agreement and we are paying Oxonica the market price for the additive. So if we are still using it after six months that will be a pretty obvious endorsement of their claims. If we stop using it on the thousand buses, the message will be clear too. "
http://www.newscientist.com/news/news.jsp?id=ns99994271
Surface area
Doping test
