Diesel Freak has Dyno'd his truck
Oil mix question
Mirrors
well, now that I had my new clutch, I wanted to see what I was putting to the ground.
Here is what the acceleration test's showed. Keep in mind that I have 35" tires.
Stock, 275's, boost module, K&N, 4" exhaust.
233. 1 HP @ 2750 RPM
483. 2 FTxLBF @ 2250 RPM
max boost 28 PSI
Above BOMB's with Power Puck
267. 2 HP @ 2450 RPM
703. 4 FTxLBF @ 2070 RPM
max boost 31 PSI
I then had them load the engine down from 2700 RPM to get peak full load torque since I could not get full boost during the acceleration tests. Here is the final result of that run.
794 FTxLBF at 1950 RPM
that figures out to 294 HP!!!!!!!!!!!!!!!!!!!!!!!! :p
max boost 38 PSI
max EGT 1150F
No wonder my stock clutch died!:eek: :D
Very Respectable..
Those look like some good numbers with what you have. I hope I get my clutch before Dyno Days. You forgot to mention 3. 55 gears :eek: w/35" tires.
I was very happy with them. :D I completely spanked and emdarased the owner of the 88 Firebird with an modified :rolleyes: L98 350 his best was 202 HP at 4500.
Are you going to Robs this saturday?
