Also, You may be "more smarter" than I, but why isn't the BSFC at the max torque RPM?... which I think for the 600 Series motor is 1650...
Until you get very acquainted with the truck, I would not do anything at this point. Get used to it as it is, then if/when you change something later, you will be better able to judge it's affect.
Any claims of huge mileage gains by a fuel box or programmer are mostly false, you may get 1 to 1. 5 mpg gain by timing only and that is doubtful unless you drive delicately.
Does your truck have a standard or auto trans? Since you are claiming a 600 series, it must be a 2004. 5 model year with the 325 hp motor. If you are hell bent on a power/fuel upgrade, I also vote for Smarty(JR or SR), but until other upgrades like a built auto trans or clutch are completed, you will be limited to Smarty's lowest level of performance, lest you be wanting to waste $ on repairs...
Jess
JJ - You were right when you sad take the time to get acquainted with the truck. Sometimes I get caught up in the whole "You need a chip or else" type of thinking. I work as a Paramedic so I get the crazy driving out of the way at work. Lol. At home in my personal vehicle I have found that I drive a lot slower and pull out and stop like you are supposed to and I have been getting good numbers which is great! I have read that by upgrading the exhaust and possible a larger intake basically let the truck breathe and "exhale" it helps all around and may help a tiny bit with mpg's. Any truth to that? Do you or anybody have a recommendation for exhaust or intakes?? I have standard all around right now I would love to have that Cummins rumble with the exhaust what do you run?
Bill
