Because the Dodge has the Cummins... ... ... I would pick any truck that had the Cummins. As you are aware,I have had all the infamous Dodge failures that are commonly discussed on the forums. And those of us who follow your posts and remember every single detail about problems that you have posted about your past two vehicles... . the 01' and 06',know that you yourself have experienced many of the same issues. Both of your trucks were 2 wheel drive so you did not have the same problems with the front-end that we all do. Your 01' had a VP44 issue and APPS problems and again,your truck was not plaqued by the somewhat lackluster automatic transmission... the 47E. The 06' had the much better 48E but was replaced early in its life with a DTT,if memory serves. However,you had to replace the very expensive injectors on the 06'. Now I realize that you're going to counter me by stating the VP on your 01' was mis-diagnosed and replaced unnecesarily but I know you are a very smart man. I think you have read and witnessed enough here on TDR to understand that it was only a matter of time before it failed... . either by a lift pump failure or other means. Can't recall how many lift pumps you said you replaced but I do remember more than one! All it takes is one and the VP is wounded!
Just so we are on the same page... ... I love my truck and have upgraded my trucks failures with all the parts and available information that is commonly referred to here on TDR. I have certainly payed my fair share into this truck to make it a reliable and stout pulling machine. Much more so than any other truck I have ever owned. Again,mostly Dodge related... ...
I have modded my truck,as I am very much aware that you detest 'magic boxes',and will go on to say that most of my mods are purely mechanical upgrades and were installed for towing prowess only. I have a Bully Dog Module but the timing makes my idle so choppy,I refuse to use it..... short of the most brutal of hills.
I am not a Dodge fan because this truck has made me that way. I am a Cummins fan and that influences my decision to keep this truck no matter what the Dodge part of the equation dishes out. I would like to think that many Cummins enthusiasts would purchase ANY truck that came equipped with the 5. 9L,whether it was a Ford,Chevy,Toyota or Dodge! IMHO!
Alan
Alan,
Your memory of my truck failure experiences is fairly accurate but not entirely. I did replace a VP-44 with a Cummins reman pump as a result of a misdiagnosed problem when my '01 had a little over 100k miles. The truck now has 350k miles on the odometer which means the reman VP-44 has provided around 250k miles of reliable performance. I don't see anything to complain about. The truck had Bosch RV275hp injectors installed by Joe Donnelly when it was very young but NEVER had a black box that altered timing or fueling. I wonder if THAT is the reason my luck with Dodges has been better than others?
The OEM transfer pump failed one afternoon when the truck had 60k miles on it and I was a block or two from the local dealer when it stumbled on acceleration in third or fourth gear. I pulled straight into the dealer's service drive and the pump was replaced under warranty. I never experienced another failure. At my insistence, my former Dodge mechanic friend reluctantly replaced the second pump somewhere under 200k miles because I was running hard, transporting trailers, and didn't want to chance a failure on the road. The maintenance log is still in the truck although I haven't looked at it in years. I don't think another pump was ever replaced. I did have a flow test done once or twice. I purchased and carried a third pump but it has never been installed. About two months ago I persuaded my son-in-law and daughter to allow my mechanic buddy to perform a flow test on the very "experienced" pump that he had installed for me, probably in '04. He pronounced it still good. The pump I purchased years ago is still in the original Cummins box on a shelf. The old Dodge is only used as a spare vehicle and spends most of its time parked now enjoying a well deserved retirement.
I did replace about six APPS modules . . . about every 45,000 miles due to failure! APPS modules were definitely a very weak and disappointing Dodge component on my '01 but not all 24 valve trucks have had as many failures. I have always believed there was something about my truck that made my experience worse than most. It may have been due to using a Jacobs exhaust brake from day one. Using the eb caused me to open then close the "throttle" a lot to control deceleration. When I was transporting I carried a spare APPS most of the time and could change one in ten minutes. Twice when I failed to carry one I limped it into dealers to buy one. Another time it failed on I-5 north of Seattle. I pulled off into an abandoned gas station in a small town and called a local dealer. Their parts delivery truck delivered an APPS to me where I was parked. Because it was a manual six speed, I was never stranded on the road. Other than repeated APPS failures my '01 was (and still is) a very reliable truck.
You are completely mistaken about injectors in my '06 Dodge. I replaced an FCA but NEVER an injector. All injectors were original when I sold the truck at 230k miles. I worried about injectors when it had 200+k miles on the odometer, in part because of what I read on TDR. I took it to a dealer and had a engine diagnostic test performed by a trained and skilled Cummins tech at around 210k miles. The diagnostic determined that all injectors were performing within specs. It always ran strong and got good fuel mileage.
I did have a full DTT built for the '06 but it proved unnecessary. The tailshaft bushing slipped out of place (it was pressed in) at 135k miles while I was working on the west coast. That caused the tailshaft seal to fail and it began dumping ATF out of the tailshaft. I had a high-paying load hooked up to pull from Oxnard, CA somewhere back east so I filled it up with ATF, purchased a few extra quarts, and headed east. It leaked ATF so badly that I had to stop and add three or four quarts to limp it, barely, up the hill into Flagstaff. I surrendered my load to another driver and had a local dealer install a new tailshaft seal and limped it home to Texas.
I assumed (incorrectly) that I had damaged internal parts and the torque converter because it ran low on ATF with a heavy trailer behind. I took it to a skilled automatic transmission rebuilder and authorized DTT installer and had a full DTT rebuild. When the transmission was disassembled it was fine. All it really needed was a new tailshaft bushing and seal. At the time, summer of 2007, I was making lots of money transporting and was planning to continue for another couple of years so I spent $6400 for a full DTT. Not long after the DTT rebuild fuel prices began rising dramatically, RV sales began slowing, and I realized I was tired and becoming burned out with transporting. At the end of October 2007 I had run 400,000 miles in two years and nine months, had survived too many trips and too many mountain passes on snow and ice, the industry was slowing, and I expected it was going to tank (it did) so I "retired. " I think my '06 was an extremely reliable truck also, especially when I consider how many of those 230k miles in one year and nine months were towing miles, many of them in excess of Dodge's specified GCWR.
Complaints about Dodge trucks that are less than perfect, and usually posted over a long list of modifications, frequently cause me to post a strong defense of my three Dodge trucks. I tend to remember the strengths and advantages of Dodges, not the minor imperfections.
You were correct, my trucks have all been 2wds although my currrent C&C uses a 4wd front end except for driveshaft, differential, and transfer case. I'm not a fan of 4wd. My trucks have not used huge oversized wheels and tires or been pounded over backroads and trails.
I'm a defender of Dodge trucks because I have enjoyed outstanding service from the three I've owned. Other than an overpriced automatic transmission modified rebuild (my bad decision) my cost of ownership of three Dodges used for heavy highway towing has been extremely low and I have NEVER experienced a breakdown that left me stranded.
I understand that a truck is a mechanical device made my men and it will wear out. Driving style, service application, maintenance methods, and the presence or absence of modifications make big differences in the experiences we have with our trucks.
I am also a Dodge defender because I transported alongside lots of Furd and GM owners. I heard their comments and heard about their truck failures from other transporters. I knew of many Furd owners back in '05 and '06 who were financially ruined by Furd 6. 0s and talked to a few GM owners who compared their experiences to mine and traded for Dodges. All but a very small number of old transporters who stayed in the industry owned and used Dodges. They gave up their former brand loyalty to GMs and Furds because they learned. I did know a couple of them who put lots of miles on Furd 7. 3s, partly because they owned one when they started and couldn't afford another truck. I never ran across or heard of a GM with more than about 300k miles. I road on one belonging to a fellow transporter once. It was used up at 300k.
We each make our own choices. I will only spend my money on Dodges with Cummins engines. I have owned lots of Chevy and Furd trucks before I bought my first Dodge in '01.
