Diesel smell in AC????
overall wheel size/ gearing ratio formula
Dodge Cummins Wannabe
Just got my truck, put 500 miles on it in two days. For the last 50 or so miles I've noticed the smell of diesel, in the cab, when the A/Cs running. Any ideas???:confused:
I'd guess that its just the fresh crankcase oil. It should go away soon. Mine smells like that every time that I change the oil.
Another possibility is that you have a fuel leak. If that's the case you should be able to see some evidence such as a drip or puddle under the truck.
Check the cowl seal. They can come loose and let fumes from engine compartment pass between cowl and hood. From there it's a short path to your fresh air intake.
Had the same problem.....
Fresh oil always does it.
Took it to the dealer 4 times and they said they have tried everything to get the cowl seal to stay on. Idiots!
I just filled the seal with silicone caulk and stuck it on. Hasn't moved since. That helped keep the aroma down, but after an oil change it still smells strong for a few hundred miles.
Garrett
If you get a closed crankcase system (like the Walker airsep), you'll never smell that again! Plus the other benefits... .
smelly truck
i couldn't afford that option, so mine gives me the aroma frequently. fortunately, i read about it on tdr, before i took it back to the dealer and made a fool of myself. i thought i had an exhaust leak, but couldn't figure out why it got better after i drove it more miles. then i changed the oil and it started over again. once again $35 for tdr was money well spent... ... ..... 'course that doesn't take into account the BOMBing i've learned about. somehow i suspect the eventual talley will be around -3,965 dollars give or take a few thousand dollars... ... ... . lessee, upgraded tc, valve body, fueling box, injectors, boost module, gauges , exhaust... ... ..... does it ever end??:confused:
smell
shooter,
i plan to address the breather soon. on my harley, i simply ran the vent back under the frame and terminated in a filter that i believe k 'n n made. prob do the same for the hd ram. :cool:
