Diesel Speedster (Opel) UPDATED 2/17/05
Bigger and Better(?) than the CXT...
History Channel now - Modern Marvels about engines
Excellent performance: 250 km/h top speed, only 2. 5 liters fuel consumption
Powerful new diesel engine: 1. 3-liter, 82 kW/112 hp CDTI ECOTEC
Exceptional aerodynamics: cD = 0. 20
Saving can be so fascinating: At the Paris Motor Show the Opel Eco-Speedster technology concept impressively demonstrates the potential that exists in a combination of advanced driveline technology, sophisticated aerodynamics and systematic weight-saving construction. The world premiere of this spectacular prototype marks the start of the biggest diesel campaign in Opel's history. By the end of 2003 the company will introduce four all-new common rail diesel engines across the range, with power outputs of up to 130 kW (177 hp). The outstandingly efficient Eco-Speedster prototype with its spectacular long-tail body demonstrates impressively the performance potential of the future 1. 3 CDTI ECOTEC engine: During initial testing, the 82 kW/112-hp concept car reached a maximum speed of over 250 km/h, while fuel consumption according to the MVEG cycle was a miserly 2. 5 liters per 100 kilometers.
The two-seat prototype is based on the mid-engined Speedster roadster, but features new, carbon fiber bodywork with much improved aerodynamics. With significantly reduced drag (cD= 0. 20) and even lower weight (around 660 kg), the Eco-Speedster takes up where another Opel prototype left off 30 years ago: On June 1, 1972, at the company's Dudenhofen proving ground, a modified Opel GT with 95 hp, 2. 1-liter turbocharged diesel engine made the headlines by setting several world records for diesel passenger cars and reached a top speed of 197. 5 km/h. Shortly afterwards, Opel launched the Opel Rekord 2. 1 D, its first diesel-engined passenger car.
The new Eco-Speedster is proof of the progress made in the last 30 years and of the diesel engine's amazing passenger-car career. When the record-breaking GT made its sensational appearance, it was the first time that "sports-car performance" had been associated with the diesel engine. The performance of the very compact unit in the new engineering study is particularly impressive. The all-new ECOTEC-CDTI diesel, with the latest multi-jet common rail fuel injection, four valves per cylinder and variable-geometry turbocharger, has a displacement of only 1. 3 liters.
Powerful, Compact and Clean: The World's Smallest Four-Cylinder Diesel
This innovative engine is notable for its compact dimensions (length/width/height: 460/500/650 millimeters). In terms of fuel consumption, emissions and refinement it proves to be one of the best diesels of all. Compared with other current engines of similar output, fuel consumption will be down by approx. 10 percent and emissions will be cut by 30 to 40 percent and thus outperform the Euro 4 limits. At 1251 cc, this ECOTEC unit is the world's smallest four-cylinder diesel, but with regard to output and torque it can compete with substantially larger engines.
The basis for this performance potential is the ultramodern design of the new 1. 3 CDTI ECOTEC engine. An alloy cylinder head tops the weight-optimized cast-iron engine block (bore x stroke 69. 6 x 82. 0 millimeters). There are four valves per cylinder, operated by roller cam followers from two chain-driven overhead camshafts. The latest multi-jet direct injection system with fuel supply by 'common rail' at a pressure of 1600 bar is another noteworthy feature.
Fuel supply to the five-hole nozzles is controlled via an ultramodern solenoid valve. The fuel injection system's response time is less than 20 millionths of a second, ensuring extremely fine metering of the fuel and up to five injections per working cycle. This not only keeps fuel consumption and exhaust emissions extremely low, but also ensures smooth, low-noise operation. Pilot injection helps to reduce the once notorious diesel-engine knock in the warm-up phase to a hardly identifiable level.
Slim, Long and Flat: an Extremely Aerodynamic Body
Whereas the diesel engine is of completely new design, the advanced engineering team at Opel's International Technical Development Center (ITEZ) was able to make use of a tried-and-tested basis for the car itself. "The Speedster was nevertheless subjected to some fundamental modifications," explains Walter Treser, head of Opel's Advance Engineering department. "In order to achieve our own target of over 250 km/h top speed and a standard test consumption of only 2. 5 liters per 100 kilometers, considerable improvements in aerodynamics and weight were essential. " By facing this challenge, the engineers had an opportunity to demonstrate the limits of feasibility in this area.
Calculations soon showed that the target performance figures could only be achieved by reducing the drag coefficient by half - definitely a highly ambitious goal. And in due course it became clear: This target could not be achieved by pure optimization - more radical steps would have to be introduced.
The first step was to reduce the Speedster's frontal area. The design engineers lowered the now rigid roof of this already low-slung sports car by another 167 millimeters and gave the car a more steeply raked windshield. The result: The Eco-Speedster's height is a mere 950 millimeters, which would make it almost impossible to enter and leave through standard doors. The design study was therefore fitted with gullwing doors. An extremely small detachable steering wheel also helps to make entering the car more convenient and gives the driver more room. The backs of the carbon-fiber reinforced racing seats were also given a more inclined position. Since occupant comfort was not yet one of the main priorities, the cockpit was also reduced in width above the waistline. The result: A frontal area, in technology identified with the letter A, of only 1. 4 m2 - 12. 5 percent less than the production Speedster.
On this basis and according to the motto "length means speed", the next task was reducing the drag coefficient. The most striking novelty is the long tail. It extends 184 millimeters farther back, so that the airflow clings closer to the body and generates less turbulence. The impression of extra length is enhanced by the panels above the mid-engine; looking at the car from the side, there is a continuous gently sloping line from the windshield frame to the tail panel. Further visual clues to the excellent aerodynamics are the almost complete paneling of the rear wheel cutouts and the smooth front wheel covers. In wind tunnel tests, final detailing led to the results calculated by the design computer in advance: With a cD of 0. 20 and an overall aerodynamic drag (cD x A) of 0. 28 m2, the Eco-Speedster slides 47 percent more easily through the air than its production counterpart.
Classical, Clear, Modern: a Design Study Typical of Opel
Stefan Arndt, designer of the Eco-Speedster, is not only happy about the technical results obtained by the modifications: "With its long tail and the pronounced cockpit dome including the gull-wing doors, the design study reminds me of the classic long-distance cars of the 1960s. We succeeded in maintaining the characteristic edges of the Speedster as well as typical elements such as headlamps and tail lights and the trapezoidal front-end styling. The Eco-Speedster is not in the least nostalgic, however: it looks like an Opel and is recognized as one at first glance. "
In order to realize the so far unique combination of exemplary moderate consumption and sporty performance, according to the formula 2. 5 x 250, the engineers had to go the limits as far as weight saving and rolling resistance were concerned. What can't be seen under the elegant light-silver competition-car finish, but shows up on the scales: all elements of the body's outer skin are made of carbon fiber. Based on the Speedster's light, rigid aluminum frame, the weight of the prototype has been reduced to 660 kg. Further factors such as particularly low-resistance size 175/55 R 17 W tires and special low-friction engine oil complete the Eco package for the Speedster.
Explaining the prototype's background, Opel's Chief Executive Officer Carl-Peter Forster says: "The Eco-Speedster symbolizes our comprehensive diesel offensive and at the same time demonstrates Opel's engineering expertise in power trains, weight-saving design and aerodynamics. By the end of 2003 we will have introduced four new, state-of-the-art common rail diesel engines with a wide range of power outputs, low weight and moderate fuel consumption. "
Originally posted by Morphious
month or so ago Morph.
Oh yeah I remember it well and ever scince I have been intrigued. I went to the N. y auto show and this had re sparked my love for this thing ... . however I found some sweet sites for it (Gotta translate it but hey why not). Man it sure is a sick lookin' ride tho!
... . all I want to know is how much and when.
Ditto. Any chance they'll be selling these things here in the states? Tool Man, can you post a link to a couple web sites?
Rüsselsheim - Saving can be so fascinating: At the Paris Motor Show the Opel Eco-Speedster technology concept impressively demonstrates the potential that exists in a combination of advanced driveline technology, sophisticated aerodynamics and systematic weight-saving construction. The world premiere of this spectacular prototype marks the start of the biggest diesel campaign in Opel's history. By the end of 2003 the company will introduce four all-new common rail diesel engines across the range, with power outputs of up to 130 kW (177 hp). The outstandingly efficient Eco-Speedster prototype with its spectacular long-tail body demonstrates impressively the performance potential of the future 1. 3 CDTI ECOTEC engine: During initial testing, the 82 kW/112-hp concept car reached a maximum speed of over 250 km/h, while fuel consumption according to the MVEG cycle was a miserly 2. 5 liters per 100 kilometers.
And Lastly The NEw generation of Diesels that are not only Euro class 4 ... but have power too.
TWINPORT technology lowers fuel consumption by as much as 23 percent. New 1. 3 and 1. 7 liter common rail turbo-diesels meet Euro 4 requirements. Dynamic looks, agile handling thanks to shorter steering ratio.
The new edition of the Corsa comes with a fresh, dynamic design and a broad range of technical innovations. Highlights include new 1. 3 liter and 1. 7 liter common rail turbo-diesel engines and a newly developed 1. 4 ECOTEC gasoline engine with TWINPORT technology. The Corsa 1. 4 TWINPORT requires - depending on the transmission chosen - up to 23 percent less fuel than the previous Corsa 1. 4 with the same power.
Electric, speed-sensitive power steering is more responsive and thanks to a shorter steering ratio the new edition Corsa features improved handling. With an expanded range of standard equipment, as well as new options like ESP or Xenon headlamps, the Corsa in its third year of sales is more technically mature than ever. The "Easytronic" automated manual transmission is now available for all gasoline engines up to 1. 4-liter displacement and for the new 1. 3 CDTI. Besides the new engines, an adaptive service interval indicator makes the Corsa even more economical to operate. The new edition Corsa's exterior features distinctive 3D ellipsoid headlamps with three cylindrical units for low beam, high beam and indicators. The front and rear bumpers are color-keyed and come with integrated inserts to protect them against minor collisions. In the interior new upholstery material and colors provide a fresh ambience. The Corsa now comes in 15 different colors and together with numerous options, accessories and five equipment packages Corsa customers have a wide range of possibilities to individualize their cars.
From now on, the comprehensive standard equipment of all Corsas includes a Brake Assistant and a "follow me home" light function, which provides exterior lighting after the car is parked. The rear seat bench can now be locked in two different upright positions. Both the seat back and rear seat bench cushions can be folded separately. Even more flexibility in the rear is provided by a 1/3 to 2/3 split rear seat bench and comes as standard equipment beginning with the Enjoy equipment line. On request the electronic stability program ESP, a speed regulator and xenon headlamps will also be available starting in the fall.
TWINPORT: the new formula for gasoline savings in engines with up to 1. 6 liter capacity The engine program of the Corsa consist of six four-cylinder units - four gasoline and two common rail turbo-diesels - ranging from 1. 0 to 1. 8 liters displacement and from 60 to 125 horsepower. All engines comply with the Euro 4 emission standard. The gasoline engines bring the innovative TWINPORT system to the Corsa program for the first time on a wide basis. This intelligent fuel-saving technology for gasoline engines with displacements up to 1. 6 liters, achieves a significant reduction in fuel consumption by using a variable intake manifold in combination with high rates of exhaust gas recirculation. For example, the new 1. 0 ECOTEC TWINPORT engine in the Corsa needs only 5. 3 liters of fuel per 100 km, that's 0. 2 liters or around three percent less than the previous 1. 0-liter gasoline unit. Fuel savings are even greater with the newly developed 1. 4 ECOTEC TWINPORT engine, which is based on the 1. 2 ECOTEC unit. The 1. 4 TWINPORT consumes only 5. 9 liters per 100 km. That is 0. 9 liters or nearly 13 percent less than the predecessor with the same power output and five-speed manual transmission. Compared to the Corsa 1. 4 with four-speed automatic transmission offered until now, the new TWINPORT version with Easytronic needs 1. 7 liters, or more than 23 percent, less fuel.
CDTI ECOTEC engine: Latest generation common rail turbo-diesels High operating efficiency is also one of the strengths of the new 1. 3- and 1. 7-liter CDTI ECOTEC turbo-diesels. Both engines incorporate the latest generation of common rail direct injection technology, meet the stringent Euro 4 emission standards, and feature low fuel consumption in combination with high performance and refinement. The extremely compact 1. 3 CDTI ECOTEC is the smallest four-cylinder common rail diesel engine in the world. Thanks to its Multi-Injection system it requires, in the Corsa, only 4. 5 liters diesel per 100 km. The 74 kW (100 hp) 1. 7 CDTI ECOTEC features a turbo charger with variable turbine geometry and develops a maximum torque of 240 Newton meters . The fuel consumption of the Corsa 1. 7 CDTI is only 4. 8 liters diesel per 100 km. Easytronic: Automated manual transmission now also available with a diesel engine All Corsas come standard with a five-speed manual transmission. As an option the two TWINPORT engines, the 1. 2 ECOTEC, the 1. 3 CDTI come with the Easytronic automated manual transmission. Easytronic combines the convenience of an automatic with the sporty and economical characteristics of a manual transmission. There is no clutch and the driver can easily switch at any time from manual to automatic gear selection, or vice versa. The repair- and service-friendly construction, moderate insurance rates and long service intervals (two years / gasoline: 30,000 km; diesel: 50,000 km) make the Corsa economical to run. The new, adaptive interval indicator also takes into account the individual driving profile and informs car owners on a cockpit display when the next service is necessary.
Update!!!!
It's been allmost a year scince I fired this up but BOY Opel is kicking some Arse.
Opel Twin-Turbo Revolutionizes Diesel Engine Technology
Premiere: Two-stage turbocharging for first time in diesel passenger car
World record: 1. 9 CDTI twin-turbo in Vectra OPC with 112 hp per liter displacement
Up to 50 percent more power for same fuel consumption
With its revolutionary twin-turbo technology, Opel announces the next big step forward in the development of modern diesel engines for passenger cars. For the first time, Opel engineers have succeeded in applying two-stage turbocharging to a compression-ignition engine that is suitable for everyday driving: The Opel Vectra OPC engineering study presented at the Essen show in November 2003 and now at the Geneva Motor Show has a 1. 9-liter CDTI twin-turbo engine which produces 156 kW (212 hp). The specific power output of 112 hp per liter displacement is a world record for turbo-diesel powered passenger cars. The 1. 9 CDTI twin-turbo unit starts to deliver its maximum torque of 400 Nm at only 1400 rpm, complies with Euro 4 exhaust emission standards, and uses only 6. 0 liters of diesel fuel per 100 kilometers in the European test cycle.
The heart of the twin-turbo technology is forced aspiration of the diesel engine through two exhaust-driven turbochargers, which unlike “biturbo” systems operate in series rather than in parallel: A smaller, highly responsive turbocharger for the low engine speed range, a larger turbocharger designed for high output to take over as the revs build up. Thanks to its superior efficiency, the twin-turbo system can achieve an extremely high specific power output, without disadvantages in fuel consumption and exhaust emissions.
Hans H. Demant, Executive Director Engineering at Opel, says: “We are proud to be the first manufacturer to apply this two-stage turbocharging principle to a production diesel engine. Our twin-turbo technology is particularly economical, pro-environmental and fun to drive. ”
The secret behind “twin-turbo” is the clever two-stage forced aspiration principle. By using a small high-pressure turbocharger for the first stage, the engine responds readily to the gas pedal at lower speeds without suffering from “turbo lag”. Up to 1800 rpm this high-pressure turbocharger works alone and compresses the intake air at up to 3. 2 bar boost pressure. Between 1800 and 3000 rpm, a larger low pressure turbocharger joins in – both turbines run together in this engine speed range. Above 3000 rpm, only the larger turbocharger continues to deliver charge air to the cylinders. The complex control of both chargers is via a valve in the engine’s exhaust system, controlled by engine speed and load.
Excellent basis: New generation of 1. 9 CDTI ECOTEC engines
The twin-turbo system was developed by a team of specialists in the Opel motor sport department OPC (Opel Performance Center) led by Donatus Wichelhaus. “The enormous potential of our twin-turbo engine can be seen from the mean effective pressure values it achieves: Whereas traditional turbo-diesels have a mean effective pressure of 17 to 19 bar, the 1. 9-litre twin-turbo reaches 26 bar," explains Wichelhaus. The mean effective pressure of an engine is average working pressure acting on the pistons during the combustion process – the higher the value, the higher the power output. Wichelhaus continues: “For the twin-turbo principle to be applied successfully, the engine block must be particularly robust and capable of withstanding the enormous pressures, even after the vehicle has covered a high mileage. In the new generation of 1. 9 CDTI ECOTEC engines we have an excellent basis. ”
Vectra OPC: 212 hp from 1. 9-liter engine with fuel consumption of only 6. 0 l/100 km
Depending on the development objective, the twin-turbo can be designed either for high performance or for maximum efficiency in its consumption of fuel. Compared with a naturally aspirated diesel engine, power outputs can be raised by up to 50 percent without increasing fuel consumption. Alternatively, consumption can be reduced by as much as a quarter without loss of power. Opel has chosen the first route for the 1. 9 CDTI twin-turbo engine used in the Vectra OPC study. This high-tech engine delivers a peak power output of 156 kW (212 hp) from just 1. 9 liters displacement. :eek: The resulting specific power output of 82 kW (112 hp) per liter is a world record, not matched by any turbo-diesel in a standard production car.
Two-stage turbocharging combined with the latest common-rail fuel supply, variable multi stage fuel injection and twin charge-air intercoolers provide the increase in power and the maximum torque of 400 Nm, which is available over a wide engine-speed range from 1400 to 3600 rpm. With this engine the Vectra OPC accelerates from 0 to 100 in 6. 5 seconds; the top speed is an electronically regulated 250 km/h. At 6. 0 liters per 100 km in the European test cycle, fuel consumption is at the same low level as the production 1. 9 CDTI units, and like these the twin-turbo engine can be fitted with a maintenance-free diesel particulate filter (DPF) that works without additives. Exhaust emissions already comply with the Euro 4 standard for new vehicles registered after January 1, 2006.
that's where the American market can learn, when they have to meet (higher) EPA standards :-laf
Back home (Holland) my brother drives an Opel Astra TDi for work and my dad has a Mercedes Benz 2. 5 liter 5cylinder diesel -> talking about getting great mileage :)
And just like this Eco Speedster they can still haul *** :D
It's just that in the US (almost) everybody thinks of diesels as being noisy, stinky, environmental unfriendly and so on, but that's an old misconception that doesn't seem to want to fade ..... :rolleyes:
