Diesel Truck Pull May 27th Franklin, Indiana 3 classes!
Indy Dyno Day
Central Ohio Hog Roast & Dyno Day
http://www.srdieselconcepts.com/id22.html
Memorial Weekend Truck Pulls
May 27th 2006
Registration: 12:00-3:00PM Start 4:00PM
Johnson County Fairgrounds
Franklin,Indiana
8000lb Modified 4X4 Diesel Trucks $35
8000lb Street Stock 4X4 Diesel Trucks $30
8000lb Pro Stock 4X4 Diesel Trucks $30
8000lb Johnson County Bragging Rights $20
Diesel or Gas 4X4 Trucks
Street Stock 4X4 Gas Trucks $20
General Admission $5. 00
Pit Pass $7. 50
Contacts: Scott Logsdon Ray Quinn
317-538-8259 317-441-5359
Volunteers needed please contact above or E-mail us!
-- email address removed -- or -- email address removed --
8000 lb. Street Stock 4x4 Diesel Trucks
1. Single turbo,Maximun 2. 8 inducer
2. Hanging front weights allowed
3. Must pull off of "Reese" style hitch (I called and verified that this basically means no "trick" hitches that connect to the axle or bed, adjustable hook point type hitches are ok that most of us pull with are ok)
4. Traction bars & blocked suspension permitted
5. 26" Hitch height
6. No Nitrous,Propane, or Water Injection
7. DOT Tires, no cut or bar tires
8. Seat belt or other safety restraint required
8000 lb. Pro Stock 4X4 Diesel Trucks
1. Single turbo, no limit
3. Pulling hitch allowed (26" hitch height)
4. Traction bars & blocked suspension allowed
5. Water injection allowed
6. No nitrous or propane
7. Dot tires, no cut or bar tires
8. Air shutoff or electric fuel shutoff required
9. Manual transmission must have SFI blanket covering bellhousing
10. Seat belt or other safety restraint required
11. Exhaust must exit straight up or down,with two 3/8" bolts in a cross pattern within one inch of each other, and as close to the turbo as practical.
Class Prize Money
Modified 4x4 Diesel Trucks (at least 5 trucks to pay)
1st- $500 2nd $250 3rd $100
Pro Stock 4X4 Diesel Trucks (at least 5 trucks to pay)
1st- $300 2nd $150 3rd $75
Street Stock 4X4 Diesel Trucks (at least 10 trucks to pay) 1st- $150 2nd $100 3rd $50
Street Stock 4X4 Gas Trucks (at least 5 trucks top pay)
1st- $75 2nd $50 3rd $25
Bragging Rights class Trophy only.
Bragging Rights Class Rules:
Truck must be licensed and registered in Johnson County
Driver must live in Johnson County
No Limits on Truck (Must be driven to Pulls)
Guys this looks to be a great pull and should bring out some great trucks!!
This is only 20 minutes south of Indianapolis.
