Diesel_Dan...The man for FASS issues!!!
Helix cams
Group Buy For 2nd Gen Juice W/attitude
The fitting that he sent worked great with the 24psi spring... holding steady at 15psi, awesome!
And the other replacement spring he sent was a thicker wire... that was probably the problem with the last ones... I think this will probably last longer... having a spring with a larger diameter wire with a softer spring rate will probably do better than the thin wire with a higher spring rate...
FASS owners... this is THE MAN to ask when you have issues with your FASS!! Hopefully his replacement parts cured my too low and too high pressure problems!!!
steved
Diesel Dan tried to help me, but because Fass could not find my warranty card they turned down my warranty claim even though I faxed them the original invoice.
Diesel Dan did extend my warranty for 2 years to try to make things right.
I still wish I never heard of FASS.
The FASS was one of the best investment I ever did... now that this pressure issue is fixed, I'm good to go...
I had no trouble with them getting my registration... did you put a stamp on it or even fill it out???
steved
