Difference between 555 & 600 turbo?
Remote start on 2005 610 Diesel
2001 Edge EZ Pulse Question
Does anyone know what the difference in size between the two turbos is?What is the exact size of the new one,some guys have said it is a hy10 62mm and the old one is a hy9. But have not heard anyone say they were certain.
As per page 48 of the latest editon of the TDR
... . on all versions of this engine (3rd gen) is a HY35 with a 9cm squared exhaust housing. It now has a 3. 5 inch exhaust outlest as to the older 3" outlet... ...
The 04. 5-05 the turbo has a larger compressor wheel and housing for increased flow... ... page 49
03-04 standerd engine 22-24psi boost
2005 and previous HO engines, 25-26 psi.
62mm as previously stated.
The compressor housing is about a 12cm if I had to compare it to something (like the old hx35 comp hsg. ).
The turbine housing and wheel are the same as 03 and 04 units.
Looks to be a 9cm turbine housing from 03-05.
jwilliams,I see in your signature that you have a b1-04 ,how do they compare in size to the stocker?Is it the full b1-04 that they just come out with last month or is it a b1-2-04?
The turbo I have is the one that came out in about December time frame maybe a little earlier, but it had just come out.
Comparison, well the compressor wheel looks about the same or a hair bigger.
The turbine wheel and housing are bigger on the big (alot bigger).
Shaft is alot beefier than the stocker.
